I can’t get my desktop app to connect to my 7300 for CAT control. I am using Linux, mx-23.6 Libretto which i believe is a Debian build. The only radio model available for me to choose is TCI Network (ExpertSDR/RemoteHamRadio) #99001, but I get an error of rigctl exited with code 1. I know I have a good connection, POTACAT works fine on the same computer. I have v0.2.7 of the Debian download of the desktop app, and I have the cat control integration installed, it won’t connect either.
@WC5T How did you install the desktop app?
It should be installed via the deb using the terminal.
I would open a terminal and run: sudo dpkg --purge world-radio-league-desktop
then download the latest version of the deb from the integrations page (World Radio League) then in a terminal run: sudo dpkg -i packageName.deb
(where packageName.deb) is the name of the file.
I installed it with the Dolphin app included in the OS. I know very little about Linux…been a windows guy since NT.
Interesting. Never heard of it. I would follow the instructions above to uninstall and then reinstall
Done that several times. Can’t get the standalone cat control and integrations thing to connect either, although it does at least let me select an ic-7300 and the correct port. Just wont connect.
@WC5T There are several setting you need to set in your radio for things to work properly.
In you radio setting make sure you have the following set:
CI-V Baud rate: Auto
CI-V address: 94h
CI-V Transceive: ON
CI-V USB Port: Unlink from remote
CI-V USB Baud Rate: 9600 important
CI-V USB Echo Back: OFF
USB Send: off
USB Keying: off
*May have to turn CI-V USB Echo Back: On
Then with the apps closed open a terminal. Also you may need to allow your user access to the dialout group:
open a terminal and set the following:
usermod -aG dialout your_username
chmod 777 /dev/ttyUSB0
chmod 777 /dev/ttyUSB1
Then select your radio from the drop down, set your com port and baud rate to 9600 and connect the radio
Is 9600 baud a Linux restriction with wrl? 19200 works with potacat as well as on my windows laptop with wrl.
@WC5T its a WRL recommendation. im sure a higher baud rate could work but i would suggest 9600, theres really no benefit of a higher baud rate
Still not working. ![]()
I did have to “sudo” the terminal commands, but still nothing on the drop down
@WC5T did you add your use to the dialout group via the commands above?
Close the desktop app, then run the following in a terminal:
sudo apt install libhamlib-dev hamlib-utils
Then open the desktop app
I’m trying to link WSTJ-X to WRL. Everything is going as per the instructions in the video. When I click on the down arrow in WSTJ-X that is supposed to take me to WRL CAT Control, nothing happens. The down arrow grays out, but is doesn’t open up WRL CAT Control. I am getting reading from my 7300s. I really don’t want to make a contact until I get this set up. Help.
@N8GBS i’m not really sure what you mean by “when i click on the down arrow in wsjtx that is supposed to take me to wrl cat control”. There isn’t anything in WSJTX that will auto open any WRL app.
I would highly recommend downloading and using the desktop app as it has rig control and udp streaming built in natively and we are sunsetting the WRL integrations app (WRL cat control app) that is meant to be used with the web app.
Here are a couple screen recordings, one for how to use the desktop app + gridtracker + wsjtx and another for the desktop app + wsjtx (without gridtracker). Although i would recommend using gridtracker as it provides more information and just makes it more fun.
WRL Desktop + Gridtracker + WSJTX/JTDX = WRL Desktop + GridTracker + JTDX/WSJTX - '26-2 | Loom
WRL Desktop + WSJTX/JTDX = WRL Desktop + WSJTX - '26 | Loom
I have same-ish issue, for my Kenwood TS-850S. When I go to cat control in desktop app, it displays only CI Network (ExpertSDR/RemoteHamRadio) #99001 and the error rigctl exited with code 1. WRL Cat Control app for web app doesn’t work either. However, I can control the rig just fine using flrig.
I installed from the web download on the homepage for .deb.
My system and OS are:
neofetch
...-:::::-... nathan@sokyrad-desktop
.-MMMMMMMMMMMMMMM-. ----------------------
.-MMMM`..-:::::::-..`MMMM-. OS: Linux Mint 21.2 x86_64
.:MMMM.:MMMMMMMMMMMMMMM:.MMMM:. Host: OptiPlex 3050
-MMM-M---MMMMMMMMMMMMMMMMMMM.MMM- Kernel: 5.15.0-194-generic
`:MMM:MM` :MMMM:....::-...-MMMM:MMM:` Uptime: 1 hour
:MMM:MMM` :MM:` `` `` `:MMM:MMM: Packages: 4598 (dpkg), 28 (flatpak)
.MMM.MMMM` :MM. -MM. .MM- `MMMM.MMM. Shell: bash 5.1.16
:MMM:MMMM` :MM. -MM- .MM: `MMMM-MMM: Resolution: 1920x1080, 1920x1080
:MMM:MMMM` :MM. -MM- .MM: `MMMM:MMM: DE: Cinnamon 5.8.5
:MMM:MMMM` :MM. -MM- .MM: `MMMM-MMM: WM: Mutter (Muffin)
.MMM.MMMM` :MM:--:MM:--:MM: `MMMM.MMM. WM Theme: Mint-Y-Dark-Blue (Mint-Y)
:MMM:MMM- `-MMMMMMMMMMMM-` -MMM-MMM: Theme: Mint-Y-Dark-Blue [GTK2/3]
:MMM:MMM:` `:MMM:MMM: Icons: Mint-Y-Blue [GTK2/3]
.MMM.MMMM:--------------:MMMM.MMM. Terminal: gnome-terminal
'-MMMM.-MMMMMMMMMMMMMMM-.MMMM-' CPU: Intel i3-6100 (4) @ 3.700GHz
'.-MMMM``--:::::--``MMMM-.' GPU: Intel HD Graphics 530
'-MMMMMMMMMMMMM-' Memory: 7489MiB / 31977MiB
I cloned the hamlib repo and built it on my computer with no errors. libhamlib-dev and libhamlib-utils are installed via apt. hamlib-utils is not a valid package on my freshly updated apt repo. Verified rigctl has my radio and is working:
nathan@sokyrad-desktop:~$ rigctl -l | grep 850
2009 Kenwood TS-850 20250515.0 Stable RIG_MODEL_TS850
3042 Icom IC-R8500 20250517.0 Stable RIG_MODEL_ICR8500
3075 Icom IC-7850/7851 20250517.8 Stable RIG_MODEL_IC785x
I can use it successfully from my laptop using mint, but this Dell Optiplex it doesn’t play nice.
