Change location on Home Page Map?
I do 99.9% of my radio operation on the road. It would be nice if I could update my location on the map that shows on the home page. It currently defaults to my registered QTH, where I don’t make contacts. Maybe have it show the most recent location used in the log?
@N7FAN Hey David,
What do you mean the map on the homepage? Are you referring to the new ‘command center’? This pulls from your default location in your saved locations. You’ll simply just need to update that location.
I just figured it out. The right menu in the Operating Locations screen has a Set as Default option.
@N7FAN Hey David,
Yes that is correct. Glad you got it figured out.
