Is there a way to just copy qso’s in the qso manager to move them to another logbook while keeping those qso’s in the original logbook as well? I did a POTA activation today and had 2 contacts that were 13 Colonies as well. I would like to keep those qso’s in both my POTA logbook and my 13 Colonies log. I did a search in here but couldn’t find what i was looking for and also tried in the qso manager. I just moved them to the 13 Colonies log but I don’t have them in my POTA logbook now from today.
Thank you,
N1BND
@N1BND Hey David,
Doing that through the QSO Manager, no you would need to add the call sign in both logbooks to do that. However I would suggest against duplicating contacts as it will throw off analytics. In this case I can understand and see why you would want/need them in both so you get/give credit for the QSO for the pota activation as well as the contest. In this case I would just look at the time/date and make a note then log the call sign in the other logbook then update the time/date.
I hope this helps.
Ok thank you. I uploaded the log to the POTA site prior to moving those 2 contacts to the 13 Colonies log so I got the credit there. Still the same number of contacts total on here so all is good. I wasn’t thinking about the analytics. Thank you for the quick response. BTW, the WRL app worked flawlessly.
@N1BND No problem at all! Happy to help! That’s AMAZING to hear, so glad it worked great for you!!! Thanks for the support!!!
If you ever need anything don’t hesitate to reach out!
