CQ WWW SSB scoring question
The logbook gives a count of countries and dx entities worked but is there a way to get the total different cq zones worked without reviewing each line and keeping a tally sheet?
It looks like to get this info you would need to open each record for editing since the list of entries doesn’t display the exchange field.
Since the total zones is a multiplier and the cabrillo file header wants a claimed score this would be awesome to have if there is a way.
Until WRL works this out. You can export the .adi from the contest to a contest program like what I use (N1MM), which is free. I did that yesterday, and it was able to generate a Cabrillo file with full stats and a score that I was able to submit.
I actually thought about doing that, we use n1mm at the club shack. With just a few hundred contacts though I just exported the Cabrillo, copied the QSO entries, pasted into a spreadsheet space delimited-merge delimiters and then sorted on the zone column and did a quick count. It just seemed quicker than installing and configuring n1mm, although that is on the list! Thanks for the help.
Thanks guys for the input here!
We still have some work to do on the contest scoring engine, but we will add it! :folded_hands:t2:
