I have downloaded the .deb file and attempted to install it. The install faailsm with the message A package could not be found that allows the action to complete. More information is available in the detailed report. I cannot find the detailed report. Any help is appreciatyed…thanks.
@KK7UIV Hey Walt
If you are using a raspberrypi the linux images wont work. Pi’s use arm64 and not a regular intel chipset. We dont have a arm64 build as im not sure how stable or if it would even run on pi hardware.
You normally would just open a terminal and type:
sudo dpkg -i package_name.deb
Thanks, Brad. I figured that might be the case. If you would like someone to help you make it work on the Pi 400 and/or 500, I’d be more than happy to help. I have many years experience with Linux and Pi’s so should be able to beta test for that platform. Please let me know what you think.
Walt
KK7UIV
I would love to be able to run this on my Raspberry Pi 5 as well!
