Documentation of which fields WRL expects for a correct ADIF import?
Hello, WRL developers. I run a mobile FT8/FT4 iOS app (Greyline FT8 https://greylineft8.com) and I have had a user report to me that the ADIF files I export are not correctly giving credit for countries worked. It sounds like I might be missing a field on my export, or malforming something.
Could anyone tell me which fields WRL expects/requires on import for this to work correctly? My exported files do import with no problem to WRL, but I want to correct the “no credit for countries worked” issue.
I SUSPECT it might be that I am missing the DXCC field. But I’d like to confirm rather than guess.
I’m attaching a short two-entry log export from my app, if that helps a developer on your side quickly spot the problem.
Thanks a ton!
Generated by Greyline FT8 on 2026-07-17T20:01:42Z
<ADIF_VER:5>3.1.4
<PROGRAMID:12>Greyline FT8
<EOH>
<CALL:6>KD9PML <BAND:3>20m <FREQ:7>14.0740 <MODE:3>FT8 <QSO_DATE:8>20260717 <TIME_ON:6>184742 <TIME_OFF:6>184842 <RST_SENT:3>-20 <RST_RCVD:3>-18 <STATION_CALLSIGN:5>KB0RB <MY_GRIDSQUARE:6>CM98AI <GRIDSQUARE:6>EN53sj <COUNTRY:13>United States <NAME:13>MICHAEL RECHT <TX_PWR:2>65 <EOR>
<CALL:5>K7IOC <BAND:3>20m <FREQ:7>14.0740 <MODE:3>FT8 <QSO_DATE:8>20260717 <TIME_ON:6>182757 <TIME_OFF:6>182857 <RST_SENT:3>-14 <RST_RCVD:3>+12 <STATION_CALLSIGN:5>KB0RB <MY_GRIDSQUARE:6>CM98AI <GRIDSQUARE:6>CN88sf <COUNTRY:13>United States <NAME:25>ROBERT L FOLGEDALEN, II . <TX_PWR:2>65 <EOR>
I’ve modified my export spec to the following; note that I used a call in the Dominican Republic for this example. I believe this should satisfy the missing fields but again, would love confirmation.
Generated by Greyline FT8 on 2026-07-17T21:40:33Z
<ADIF_VER:5>3.1.4
<EOH>
<CALL:4>HI3K <BAND:3>20m <FREQ:7>14.0740 <MODE:3>FT8 <QSO_DATE:8>20260717 <TIME_ON:6>213900 <TIME_OFF:6>214000 <RST_SENT:2>-8 <RST_RCVD:2>-2 <STATION_CALLSIGN:5>KB0RB <MY_GRIDSQUARE:6>CM87XH <GRIDSQUARE:4>FK49 <CONT:2>NA <COUNTRY:18>Dominican Republic <DXCC:2>72 <EOR>
@KB0RB Hey Jon!
Thanks for reaching out. I was working with the user that reached out to you. The issue i found was the for the contacts he had with other countries, those countries weren’t listed in the COUNTRY field in the adif and there wasn’t a DXCC field in the ADIF either. I’ve attached a copy of his imported ADIF as well as an export of a few contacts in my account that show the fields we are exporting. Obviously you can ignore the ‘MY_RIG’, ‘MY_ANTENNA’ in my ADIF.
Here is a screenshot of a couple of his exported QSOs:
Let me know if you have any questions or need a hand with anything, happy to help!
@KB0RB I just did a test. I took the users exported ADIF from Greyline and then deleted the contacts and added a contact with a callsign that I put in Afghanistan. Which is a country I dont have a contact with. I added the DXCC field in the adif and then added Afghanistan in the country field and left all the other fields you were exporting the way they were. I then imported it into my account to see if it would show that I had worked Afghanistan in the analytics, and it did. So it looks like if you just add the DXCC field in your ADIF export and then make sure the COUNTRY is getting set everything should work as expected.
Here is the ADIF i used to test with:
I hope this helps!
Let me know if you need anything else!
Beautiful! I recently gave up trying to matrix this stuff myself and incorporated Big CTY for consistency with other tools out there, and I ensured the DXCC field is now part of the export. That was just purely a miss on my part, which is now corrected. Thanks for the feedback!
Next question - any idea when developers like me will be able to give our mutual customers the ability to log directly to WRL via an API key? :slight_smile: I already provide the functionality for QRZ, and am right now telling folks just to enable the QRZ/WRL integration - but many of them (myself included) would give up the QRZ middleman if we could :heart:
@KB0RB this is actually coming soon. We just had to get through WRTC. BUT the team is working on an api :wink:
As the guy with the problem, I just want to say how much I appreciate you both!
I literally can’t wait. This will make so much stuff so much easier. Then I need the GridTracker folks to work with you and get that integration native. One step at a time - starting with the software I can control myself!
@KB0RB You can currently integrate with Gridtracker, you just have to use one of the other logging options in the logging tab as there isn’t a WRL section..yet. Its all just an UDP ADIF broadcast. I use gridtracker daily with it. The way it works is WSJTX/JTDX sends the QSO data to gridtracker and gridtracker forwards to the qso data to WRL (and/or N1MM, N3FJP, HRD, etc).
I’ve reached out to GridTracker to ask if they can add a WRL option to the ‘Logging’ tab though.
Yeah I use the HRD UDP interface via CAT control currently. But it’s more software and more things to go wrong. Would rather have native keys everywhere!
Thanks for working on this :heart: I’ll be proud to be an early implementer of your logging API when we get it.
@KB0RB We’ve quietly (for now) released the initial v1 of the API. Hopefully in the next week or two we will be releasing an update that will have OTA activities support added as well. Just wanted to keep you in the loop. You can create your key via the ‘Integrations’ page and access the docs via API Reference — World Radio League
Hey Gents! Thanks for this. I still don’t get emails from the community site so I missed your heads up, but I got the newsletter in my email just now and am feverishly working on implementation. I have a question - is there no way to mark a newly created logbook as a “POTA Activation” the way we do from the UI today? Does it even matter? I want my app to create a new logbook per POTA event for the user, and would like for them to have the nice “Export .ADI” option when they’re done.
I should have this wired up in day or so, and am glad I took the time to scaffold in all the stuff I knew I’d need when I added Cloudlog. I’d still LOVE to get on the podcast sometime and talk about the implementation and why it matters!
And now I see you answered my question about the activities above. I’d really like to support that as soon as possible, it’s kind of critical to the way I’ve architected my logging module. Would definitely love to see what that looks like - I’ll press on with my current design which just creates a new logbook per activation (a concept I track in my own internal logger) and add support for what you implement as it rolls out. How stable should I expect this API to be, realistically? Is it actually a semantic v1 which will not have breaking changes introduced (thus any breaking changes land in v2) or will it be volatile?
@KB0RB Its been thoroughly tested so it should be stable. I’ll talk to the team and try and get a timeline on when we’ll have the pota support (and other OTA activities) added in.
Cool! I also notice that assigning the defaultCallsign doesn’t satisfy the logbook’s requirement for an Operator Callsignso there are extra steps required even in the UI to mark a created logbook as an OTA activity - I think there needs to be a string parameter for operatorCallsignin the body as well, or the backend should treat them as the same, or something.
Still a solid first release and I’ve already got the app updated and in review.
@KB0RB Thanks for the feedback! I’ll pass this along to the team
Cool! I also notice that since you can’t set a location when you create a logbook from the API, every created one gets marked as your default saved location. In my case, that means all of my POTA logbooks are marked as HOME - which obviously isn’t right. I think we just need to be able to set all of the various parameters that the logbook UI accepts via the API. I’m sure that’s coming at some point, but it’s creating a bit of friction at this early stage.
@KB0RB yes thats most likely due to the OTA activities not being added yet as the logbook location gets set based off of the park reference that is added.
