I was surprised that all our FD contacts (we were using my account to test is WRL was feesable to use for future endeavors) was synced with my QRZ account. I was under the impression that my FD log was going to separate and NOT synced with my general log for everthing else included my general QRZ log.
@KI5ZMB Hey Robert,
If your QRZ account is connected to your WRL account and you have auto export enabled it will sync any contact you log in your account, as designed. The imports (imports from QRZ) will only go into the logbook you select from the logbooks drop down box in the integration settings.
even though the FD log is a separate log in WRL?
@KI5ZMB Yes, any contact you make (if you have QRZ auto export enabled) inside your WRL account will be exported to QRZ, regardless of the logbook you are logging in.
Ok, that clears that up, I would like to report then, my FD log, did not export into QRZ the contest data. Within QRZ, the contest field is blank, and the exchange sent/received is also blank. It only ported over the CS, Time, Band, Freq, Mode data. If that helps with anything. I have 248 records that do not contain that information.
R
@KI5ZMB Yes that is accurate, there are no RST information exchanged during the contest (or even rst fields in the contest template) and the contest exchange data is not exported to qrz.
