Good day,
I am a avid flex user and so far I can’t get the cat control to connect to my flex. I figured I would take it 1 step at a time and start with my windows machine that is located directly at the site since my set up is 100% remote.
So far i can’t get it to connect with my smart Cat no matter what settings or selections i pick.
I have tried all the flex settings in the selection, kenwood settings, hamlib etc. thoughts?
Same here - also 100% remote with Flex. I can connect using N3FJP just fine, but the WRL app shows that there is a connection, but nothing happens. Here are my N3FJP settings, which work:
I have the same issue. I think you can only have one CAT control going. I have N3FJP running flawlessly and it logs all FT-8 contact then uploads them to 4 logs automatically. I have gotten WRL to connect before so I believe you cannot have WSJT-X controlling your rig frequencies (I could be wrong) as then the WRL connector although says connected shows zero db of traffic. I have yet to have it successfully log anything using the connector.
