I can’t find a list of support radios. Instructions mention clicking on gear but I’m thinking the gear only appears after plugging in computer and radio. A list of supported radios would make use decision easier.
@KE9DDT Are you referring to the cat control app? We are going to be releasing some fixes and updates in the next couple of days.
However with that said, you just need to download the cat control app from the integrations page, install it, open it and sign in. Then use the gear icon in the top right of the screen to access the cat control settings. From there you can select your radio, com port, and baud rate. Then click the connect radio button.
Thank you, clearly last night comming off a 12 shift was not the time to download. Got it now, Thanks, 73
