Logbook Delete stuck "in progress" for days
I’ve tried deleting an erroneous logbook for several days and it continues to show “delete in progress”. Thus, I can’t import the corrected one.
How do I get past this?
@W0RDR This was a known issue that was brought to our attention a day or so aga for large logbook deletion events. We’ve since pushed an update however since your delete was most likely started before we made the update its most likely stuck.
Give me just a sec to stop the hung process and i’ll re-trigger the delete and you should be good to go.
I’ll reach right back out.
Thanks, I’m watching for your confirmation.
@W0RDR Still working on this but i just saw you imported contacts to the same logbook i’m deleting. Do you want this logbook deleted or do you just want to import into it?
It apparently cleared the erroneous entries, so I went back into it.
If you want to delete the whole thing, I can start clean, or we can proceed from where it is now. I’m trying to get everything into my WRL logbook and transition to it as my main logging (and hopefully operating) application.
@W0RDR yeah no worries we can just leave it as is and you can continue importing as needed. Then if you want to update the name of the logbook or something you can do that via logbook settings (the gear icon).
@W0RDR Alternatively since you have a QRZ subscription and are a WRL member you can use the QRZ import integration to import directly from QRZ (if all your QSO’s are in QRZ) that will bring in your confirmations as well. Then you can use the ‘re-check confirmations’ option in the qso manager to re-check for confirmations. you’ll just need your QRZ API key from your QRZ logbook settings.
