Logs from Old Call Sign and Vanity Call Sign
I registered under my old call sign, and never uploaded my logs. I recently received a vanity call sign. I changed my call sign in WRL.
I am now ready to upload my logs from my old call sign, and then begin logging with my new call sign.
Before I pull the trigger, is there anything I should know? Is it just a matter of uploading the old call sign logs and then continue to add QSOs under my new call sign? Or do I need to create a separate logbook for both?
Hi @KZ6M ,
Thanks for joining and thanks for your support!
You can upload your logs from your old call sign, and it should show your old call sign on those contacts (this is expected behavior).
Can you try uploading those, and then just check the contact record to see it has the correct call sign?
Then, I recommend logging your new contacts in a new logbook, just to keep things clean!
You can use QSO Manager to see contacts across different logbooks.
