Hi, my location on the map (IN98fn) is shown as in the sea! I know you believe there is some security issue, so do not show the exact location on the map. However, I would prefer to see my location shown correctly on the map. As my exact location is freely available elsewhere, e.g, QRZCom, what is the point in hiding it on your map? Can this be changed? Thanks, F5VJC. Great work!
@F5VJC Your location shouldn’t be hidden on the map, that is all based off your saved location/grid square. Are you referring to your map inside your logbook, the qso map (logbooks → qso map) or the activities map?
@F5VJC Ok i see the problem, your map is showing multiple locations the QSO’s are originating from (your location). This is because some of your QSO’s were not logged with the correct location (your location). I’ve manually updated this. Here is a screen recording:
