Membership Discrepancy Question. Trying to sign up for the Basic membership at $36 billed annually which allows 50,000 Import Limits, but when i get into the screen to sign up, it say 10,000??
Basic Membership
Unlimited Contacts, Full Contest Access, Community Access, Import Up to 10K Contacts
Its just a verbiage issue on the signup page, it used to be 10,000 but we’ve recently (within the past week or so) increased the ADIF import limit. Now this is ONLY a limit on using an ADIF to import contacts. If you have your contacts in your QRZ account and have a QRZ subscription you can import everything directly via the QRZ integration option, which also brings in your QRZ confirmations and gives you the ability to re-check for confirmations on QRZ as well.
I hope this helps!
I’ll have the team update the verbiage on the signup screen to reflect the recent import limit increase.
@N3ZK NICEEEE!!! Thank you SOOOOOOO MUCH for your support! It REALLY means a lot to us all!. If you run into any issues just ping me with an @ here and we’ll get it sorted out!
