Using N1MM+ with WRL Desktop Integration listening. Contacts are being synced with WRL cloud log, but only the Class part of exchange is being sent to WRL (or received by it). The Section is missing. So score is 0 for all QSO’s unless I manually edit them in WRL log and add the Section.
I have the same issue with n1mm and wrl integration app. Except I decided not to go back into wrl and manually edit them. It is what it is now.
Ahhhhh.. maybe that’s why I had no score listed. Also of 956 QSOs only 700 or so made it from N1MM into my WRL log. I wasted time early on watching to see QSOs going into my WRL log but did not have time to pull up the leader board while using a laptop in the field.
I also had about 15 QSO’s that were logged in N1MM+ but didn’t make it to WRL. I wasn’t sure if I had turned WRL Cat Control and Integrations off and that was the reason, but I suspect there’s a timing issue since you also were missing some Q’s that didn’t synch.
73,
Rowland K4X
