@KQ4TV Ok i think i figured out the issue. I went and looked at the adif’s your imported from WSJTX. Those ADIF’s don’t have the ‘my_state’ field, only a ‘my_gridsquare’ however in all the adi’fs i looked at that you’ve imported the gridsquare is set to your qth gridsquare (even for the Oregon activations). So since the imported ADIF doesn’t have a my_state and only has the ‘my_gridsquare’ we are pulling the state based off the gridsquare in the ADIF data.
Here is a quick screen recording outlining this and showing how you can fix that data:
I’ll send you instructions on setting up WSJTX and the cat control app so you can just stream your contacts from wsjtx into your wrl logbook.
