Hello
Even though the data is 100% correct, importing the logbook from QRZ unfortunately isn’t working.
I keep getting the error message:
"Error Logs
QRZ API Key not found, please check your QRZ API Key settings."
Hello
"Error Logs
@DO4LC I just looked at your account and it looks like you dont have your QRZ API Key set in the QRZ integration settings. Make sure you are logged in, then go to the ‘integrations’ page and click where it says ‘not linked’ for both the import and export sections. On the import section make sure you select your WRL logbook from the drop down as well.
@DO4LC did you get the API key from your QRZ logbook settings? do you have a QRZ subscription?
