QSO Manager - Make more rows visible
Currently when looking at the QSO manager it shows 50 but the UI only shows like 25 and I have to scroll to view the other. All the time there is a lot of screen space below where the logs could just extend to the bottom of the screen instead.
@K7IKE So the additional space you are referring to is typically only there dependent on the screen resolution of your monitor. On a smaller screened laptop for example that additional space wouldn’t be there due to screen real estate. However I’m happy to talk to the team and see if we can increase the height of the grid to something like is shown below:
vs the default:
This is what mine looks like. On Chrome on Mac.
If I just look at a log book they extend to the bottom of the browser.
@K7IKE It looks like you have your zoom on your browser zoomed way out.
My browser is at normal zoom level
@K7IKE You may need to either use the browser zoom to zoom in a bit for the web app (it will only effect the web app itself, not other sites) or you can go to the start menu and type ‘settings’ (if on windows) then click ‘System’ and then ‘Display’ and then under the ‘Scale and Layout’ section change the dropdown that says ‘Change the size of text, apps, and other items’ to something like 125% or 150%. That will increase the size of everything though.
Looking at the screenshots you sent even, making the height of the qso manager box bigger there will still be LOTS of space due to the resolution and scale you are running your monitor
The issue is I am seeing that the table max height is being set to 450 when there is more room. I don’t know CSS that well or how your app is made but I would think this table could be made more dynamic based on browser resolution.
@K7IKE Correct, thats how I updated and sent you the current vs increased screenshots originally here: QSO Manager - Make more rows visible - #2 by K4AZE
I’ve added this as a feature request.
@K7IKE We’ve pushed some fixes for this that should resolve your issue. I would goto the QSO manager page and do a hard refresh by holding shift on your keyboard while clicking the refresh button in your browser.
looks great thanks!!!
@K7IKE thanks for your patience while we worked through this one!
