Decided to play around on FT8 today (am fairly new at it) and brought up the WRL app, and got it connected to WSJT-X. It worked like a champ! All my contacts went directly into my logbook the way it was intended. However, noticed that grid tracker 2 wasn’t really doing anything. I like having it in the corner of the screen and seeing that cool map. What settings should I change so that they both work?
You need to change your UDP port assignments. To se this up the way it works is WSJTX sends the UDP broadcast data to GridTracker and GridTracker then forwards the UDP broadcast data to WRL.
Here is a screen recording on how to set this up using the desktop app:
