Freeze log location during edit
While editing and entered log, I find it unhandy to be sent back to the top after completing an edit. If I click the edit button and then click “Cancel” I am returned to the same point in the log, but if I edit and save the edit, I am returned to the top. Could this be corrected easily?
Reported, 73’
Issue fixed! Thanks!
I’m reviewing my Dec log and I’m starting at the beginning of the month. As I see and fix an issue, it takes me back to page 1 of the log instead of leaving me on page 5. I think the original poster was saying the same thing, but if not could this be implemented?
If not, could a page number box be placed inbetween the Previous and Next buttons so that you can go directly to that known page number?
Also, I noticed that when advancing to the Previous or Next page it takes you to the middle of that page instead of to the top of that page.
Could the Previous and Next buttons be added to the top of the log in addition to the bottom so that you don’t have to scroll down to the bottom of the page when you want to change pages?
This may already be in the plans, but can a sort or search function be added to the logs? I like to find the first contact I’ve had with each state and country and it is very tedious to scroll line-by-line through each page of the log to find each instance of a state or country contact. (yes, I know, a First World issue) :sweat_smile:
I like the QSO manager, but is there a way to pull out EACH year’s contacts and put them into their own separate log (I currently log by month) while leaving the contacts in the QSO Manager intact without screwing up the total QSO numbers? Failing that, could I put a checkmark by each of the desired months and generate a map showing ALL of the contacts for all of those months?
Thanks to the team for all that they do behind the scenes.
