When using FT-8 is there away to change the offsets without having to go to the audio setup. I have gotten it to change the offsets on the main display but it doesn’t work all the time. I looked in the guide but did not see anything on it. Thank you for all the hard work with adding these great options.
Hi @KQ4NAQ, thanks for the kind words! You can change offsets right from the main Digital Operation screen, no audio setup needed:
Click on the waterfall to set your RX offset
Shift-click (or hold Shift and use the arrow keys) to set your TX offset
One thing that may explain why it doesn’t always work: offsets are locked while a QSO is in progress, so they’ll only move between contacts. Give that a try and let us know here if it still acts up. 73!
