I was looking for a print option for my logs not export but print the current page view.
@K8KCI interesting request! Could you tell us a little more about this?
What is the purpose of printing, just for records, or something else?
Do you want to print for a specific logbook or all logs?
Let us know, more information could help us understand and design this!
Thanks for being a Founding Member with us! ![]()
What is a printing log
Ok heres the deal. To get into the 10-10 club you have to contact 10 current members to become a member. They have a 10 -10 number assigned to each member.
When you contact them they will give you their number. You collect 10 numbers, names, location ect you then fill out a online form and send it in.
So i created a 10-10 logbook and put this number in the notes section.
So thats why i wanted to be able to go to the Qso manager dort by my notes first of all.
Then print them out and just send in the info
So yes i just used the windows snip program and cut out the log but had to do it twice to get it all.
When i selected right click and print with my mouse it wasn’t formated to print
Hope this helps.
printing of my log book Hope this helps ![]()
so, i went in today to try export the qso i needed so i could print them out. though i would try, so i checked all the ones i needed base on the notes column. i then exported and it put them inot a adi file type. which i understand why this it. Could get a option to print as a pdf file as well.
Simple, just put in a link that would let us be able to print a hard copy of our logs just in case something weird were to happen on the website
. This is the enternet, after all. Anything can happen when you least expect it
73,
Gregg Thacker
De, N5LYS
Yes, Yes and Yes. I would love to have this feature as well. The feature could be a function of the QSO Manager, where you select the contact that you wish to print. Standard information for any QSL (i.e., time, date, freq., mode, station worked, send rcv report.) should be hard columns that always print out. The function would allow a few optional columns to be printed as well.
Purpose: I like recording on an app, but I like paper logs as well and it takes forever to write in POTA events. I also work other contests from time to time. For example, this week I did Lighthouses on the air. Since you do not make a Lighthouse ADIF export function, I must submit paper logs. Thus I need to write on a paper log each contact and put “ARLHS Lighthouse # USA-012”. That is a lot of writing and even working it through ADIF Master app is a pain to produce a nice looking sheet with the correct information.
And it is another piece of paper floating out their that you can place your brand on. Make the function slick and easy and I know several hams who will be knocking at your door.
PLEASE, PLEASE, PLEASE with gummy bears on top.
