I got your feature request about wanting to show the SOTA summit when using the desktop app. You can hover over the activity icon to show the summit, and once you copy it to your log, it will show the summit here:
I am doing really well thanks! Their summit ID is what is missing is on the spotting side - it should have a column for the SOTA summit they have been spotted on. Take a look at: SOTAwatch3 and you can see the data that is available, and in addition to selecting the age. Ideally WRL needs to show their summit ID in the spots so you can fill out their summit ID in the log section. SOTA awards require the activator and chaser to submit logs so it is important to see that data in the spot list. Also having the SOTA summit ID would allow the ability to search. I can explain more if you need. I didn’t see any chaser logs submitted by N0WRL, I’d encourage you to give it a go and chase a few activators so you can get the sense and feel of the experience.
