A heads up for Nets for POTA activators
Is there a way to skim data from some type of Net list that will give you a heads up that your frequency will be occupied by a Net within a certain period in time? I know it’s a lot of moving parts but I have spoken with quite a few POTA activators that have been “forced” off the frequency by an upcoming Net with no plan to find a backup frequency. Maybe if we had a heads up we could avoid certain frequencies at certain times.
@KW2G I’m not aware of any “net list” the is online that has a full list of current or active nets that we would be able to pull from. You could install and check netlogger but that would require an active internet connection and it would only show the active nets going on at the current time you pull it up.
I did run across this excel document a while back that has a pretty decent list of nets that take place daily and it has the frequencies and times. This might be helpful
That is the best list I have seen so far! Thank you for the share. Net logger doesn’t always have a full picture of the active nets
If utilizing just that info, would there be any logical way for WRL to flag a frequency in a POTA/SOTA/WWFF etc log?
@KW2G not really not that i know of because that active list isn’t online anywhere its only inside the application itself.
Okay, maybe someday then! Thanks @K4AZE
I’m primarily on 20m so over a period of months I’ve just learned to stay away from 14240, 14290, 14300 for the nets and 14313 due to the lid that hangs out there that hates POTA. It doesn’t take long to become accustomed to the bigger nets and most of those are in the mornings.
