Cabrillo file failing uploading to the NAQP site
Attempting to upload the Cabrillo file for my NAQP contacts. Fails due to missing my name and QTH in the file. The following is what I see. Based on an analysis of QSO line 1 in your log, it appears that the QSO portion of your log is not formatted correctly:
Expected [freq] [PH] [yyyy-mm-dd] [hhmm] [call-sent] [name-sent] [qth-sent] [call-copied] [name-copied] [qth-copied]
Logged 14210 PH 2026-08-15 2033 AC8XU [blank] [blank] WA2MCR JOE NY
You’ll need to add the “My Exchange” fields and re-export:
Thanks, I knew it had to be something simple. Just wasn’t seeing it.
Absolutely!!! Reach out anytime!
