Distance Measurement in QSO Manager
I use the “QSO Manager” tab to look at my QSOs from across all logbooks. It would be cool to have distance as one of the column options in this screen, so that we can sort all contacts by total distance and see our longest contacts across all logbooks.
Thanks for all the work you do maintaining the site and dealing with all our bugs and feature requests!
@KC1J Hey Will,
This is a good suggestion, as the distance should be an option in the column settings. I’ll add this as a feature request.
Thanks as always for the prompt reply! Also on the filtering note, is there any way filtering by Callsign on the QSO map could be added to that as well? Would be nice to be able to filter out QSOs on club callsign
@KC1J Hey Will,
This is something we could probably add, however if you goto the QSO manager and search for a callsign and then click the eye icon it will show you the QSL card that has a map of that specific QSO and it is shareable or downloadable as well.
I hope this helps int he mean time.
