Could the font size be user selected? For my older eyes the font size is a bit small.
@NO4D Hey Good Morning Ken!
We might be able to do something like that. You can always increase the zoom on your browser though. You can go up to the (usually) top right menu of your browser and there will be a zoom option. I hope this helps.
I don’t know if it’s better or worse, but using the app you have everything in the palm of your hand, and you can also pinch the screen to zoom in and out. Whether you’re using iOS or Android, both have accessibility options to adjust everything you see to your liking, with larger fonts, quick magnification, etc. You can also use these options on PC if that’s more convenient. It’s quite simple to do, and there are videos on YouTube that can guide you through the process.
It would be nice also to use a font so that zeros in call signs show up with the line through them (Ø) so that they can easily be distinguished from the letter O.
I agree and don’t understand why all amateur radio sites do not do something like this for call signs. DX Heat uses a circle with a dot in the middle to indicate a zero.
I agree.
I don’t want or need to use options that affect all programs in order to have something easier to read. On my iPad and iPhone the pinch and zoom does not work on this program.
It’s a shame it doesn’t work for you. If you use those systems, it only affects when you want to apply it. I prepared it for my father because after age 75, his eyesight wasn’t the best. I’m sure the developers will find a solution anyway. Cheer up, 73.
Slashed zeros is definitely coming. We started working on it but got caught up in some other stuff!
We will see about font size too if possible.
Thanks!
Since your suggestion, I’ve been playing around some font options on my devices. I think I have been able to make it work for me. Thanks!
I’m glad it worked for you ![]()
