How do I move from a paper logbook over to WRL?
I know, I’m probably missing something here. I know I’m not the first guy to ask such a question, but I can’t find the answer.
I have about 25+ years of paper logbooks. I would love to move ALL of these QSOs over to WRL. You will be my FIRST digital logbook !
Is there a simple way to do this?
Can I type everything into an Excel spreadsheet and have the system import an XLS or CSV?
I’m talking thousands of QSOs, and punching them into the web interface would take a significant amount of effort. Instead a simple text format would allow me to “zone out” and dump a bunch of data in with little effort.
Appreciate any insight you can share.
PS - Thanks for making such an attractive product!
Here is an AI answer I pulled up. Hope this helps…
You do not have to type tens of thousands of contacts manually! You can absolutely use scanning and AI technology to convert your 25 years of paper logbooks into a digital format.
Because amateur radio logbooks use highly specific, structured columns (Date, Time, Band, Mode, Call Sign, RST), standard document scanners can sometimes scramble the text. However, there are modern AI tools and ham-specific workflows designed exactly for this.
Here are the best ways to digitize your logs, ranked from the fastest to the most hands-on:
1. The AI Scanning Route (Fastest)
You can scan your paper pages into PDFs or image files and run them through advanced AI document processors.
  • The Tool: You can use an AI tool like ChatGPT Plus (GPT-4o) or Google Gemini Advanced.
  • The Process: Upload a clear photo or scan of a logbook page. Give the AI a strict instruction like: “Extract the handwritten ham radio log data from this image and format it into a clean CSV table with columns for Date, Time (UTC), Call Sign, Band, Mode, and Report Sent/Received.”
  • The Output: The AI will generate a spreadsheet grid that you can download, double-check for errors, and easily convert into a digital log file.
2. Ham Radio Software & Services (Most Accurate)
There is specialized software built by radio amateurs specifically for accelerating paper log conversion.
  • Fast Log Entry (FLE): This is a free software by DF3CB. While you do type the data, it uses a brilliant shorthand system that lets you input data at lightning speed without clicking around a spreadsheet. For example, you only type the date and band once, and then you just rapidly type the times and call signs.
  • Scanning Services: If you look on the QRZ.com forums, there are occasionally ham community members with high-speed sheet-fed scanners who offer specialized logging OCR (Optical Character Recognition) services to digitize old paper logs for a small fee.
3. Voice-to-Text Transcription (The “No-Scanning” Alternative)
If scanning thousands of physical pages sounds like too much hassle, you can use your voice.
  • You can open an Excel spreadsheet on your computer, activate the built-in Voice Dictation feature (Windows Key + H on PC, or the Dictation shortcut on a Mac), and simply read your logs out loud.
  • The computer will type the call signs and dates rapidly into the cells for you as you speak.
A Vital Tip Before You Start:
No matter which method you choose, your goal is to get the final digital data saved as an .ADI (ADIF) file or a standard .CSV file. Once your 25 years of history is in an ADIF format, you can upload the entire thing into Logbook of The World (LoTW), QRZ, or the World Radio League (WRL) with a single click.
Good luck, sir.
73 K6NHL
I would also go for the scan and import to ChatGPT. Second would be a spreadsheet.
Gemini AI works really well for this as well. Same as chat GPT more or less.
Gentlemen -
I appreciate the kind responses. However, I’m still missing a critical piece of this puzzle. Once I have a CSV of my logbook, how can I import all of that information into WRL ?
Appreciate any insight anyone can offer.
Okay, after spending an hour with Google Gemini (thanks for the suggestion), I’ve come up with this procedure. Documenting here so that others can have these instructions for the future.
STEP ONE:
Create a spreadsheet using standard ADIF field names as your column headers. This ensures an error-free conversion later. Use these exact headers in row 1:
  • QSO_DATE (Format: YYYYMMDD)
  • TIME_ON (Format: HHMM in UTC)
  • CALL
  • BAND (e.g., 20M, 40M)
  • MODE (e.g., SSB, CW, FT8)
  • RST_SENT
  • RST_RCVD
Save this file as a standard CSV (Comma Delimited) file.
STEP TWO:
Convert to ADIF using ADIF Master
WRL requires an .adi file, so you cannot upload the CSV directly.
  1. Download a free Windows tool called ADIF Master (by DXShell). Download that program HERE: ADIF Master - advanced application for working with Ham Radio logbooks
  2. Open your saved CSV file inside ADIF Master.
  3. The software will automatically map your Excel columns to standard ham radio fields.
  4. Click File → Save As and choose ADIF (*.adi).
  5. Drop that file into the WRL logbook import page.
Hope that helps anyone who is trying to do the conversion from paper over to WRL
SEARCH TAGS: CSV IMPORT ADIF PAPER CONVERT
