I’d like to be able to select the exact number of QSOs I want to work with in the QSO manager. As it is, if I want to select 16 records for a bulk edit, I have to click them one by one.
Hi Tess
Ideally, there is a suitable filter criteria to filter out these 16 QSO. Otherwise, you will have to click the checkboxes on the left side 16 times. The button Bulk Edit Details will then apply to exactly these 16 selected QSO.
73 Pepe
I would like to use the select one then use the common shift function to select a sction of QSO’s.
Hi all, there are two buttons you can use to select a group of contacts at the same time.
So, if you want to select a particular group of contacts, the best way to do it is to:
- Apply a filter such as date range, logbook, band or mode
- Use the buttons in the below screenshot to select
- Then, you can take any action on those contacts you wish
Moving this to App Help and How To for now, but if you have a specific filter or selection method you want to add, just comment and I’ll create a new feature request!
