iPad Pota Logging Frequency
Good evening, I notice often I fumble with adjusting the logging frequency when using an iPad in portrait mode.. I wonder if in that format if the logging fields could be made larger as there is plenty of real estate to do so and make them a little more visible for older eyes.. I also wonder if when you tap on the field to change the logging frequency if the tap could clear it so then you can tyoe the new in as oppossed to have to back space delete the frequency… I find it very cumbersome and constantly type the new frequency at the end of the existing… maybe have a confirm change pop up if concerns of data being deleted inadvertently… love the program, keep up the good work! 73’ N2JOV
@N2JOV We will be adding some logbook settings that should help with this in the near future. Are you using the mobile app on your ipad or the web app in a browser? If you are using the web app you can always increase the zoom level via the browsers settings.
The iPad app.. mostly in the field I only adjust the frequency of changing bands
