When adding new entries to the log the “DATE” field does NOT take data, it did previously with my old QSOS added… The date field info rejects any info on this particular field. All other fields OK…What has changed in this field? -Dave,k3dgr
Checking on this David!
Hi David, I just did a few tests and I was able to log with different dates and update the dates on a previous contact without a problem.
Can you let me know more details about the issue you are running into so I can find it?
Thanks for your patience!
Fixed!!..Thanks… Looks like a great logger when completed and released…Congrats! -k3dgr
Awesome, glad this is working for you now!! Let us know any issues you have anytime and we’re here to support!
2/14/24 Only 1 field not being auto-populated “Their QTH” shoud be immediately populated from the lookup source, when typing in the new call. It has to MANUALLY typed in as it is left blank …Hmm…bug?..
all other fields are Working just spiffee!!!
congrats on the logger, 73’s Dave
Hello @K3DGR , I will be notifying the developer. Thank you
2/28/24 Additional Logging suggestions & fixes…??
- auto populate the “his QTH” field automatically during new call record input. Now manually has to be filled - waste of time
- allow sequential tabbing over each field in order, with tab key, now jumping around.
- allow up/dn arrow in header to refresh the log in reverse or current order. Not working now…
- have log remember previous “modes” to autofill fields from last new call record input. - waste of time to re-type the same info for each new record…
- add a preferenes or config sub menu to header ??
… overall, the logger is working fine for me, thanks for the hard work with the software code, and the “search” ability…, 73’s Dave,k3dgr
Thanks Alfredo… I use the logger daily and it works great for me… thanks again, 73s -Dave
Alfredo… Tabbing is sequential down to "Time " field, then jumps out completely to ENTRIES label but when positioned manually back to “Date” field, its sequential to the end of the logging input… so… … Fix the exit glitch please…
( still no auto fill for “Their QTH” field)…73’s Dave k3dgr
I will notify the developers, thanks Dave!
3/9/24 Alfredo, just checked the sequence and all seems Great… just no auto-QTH populate yet… Thanks for getting the tab sequence straightned out!.. 73’s Dave dit-dit
Hello @K3DGR
The developers are working with auto-QTH. Thank you and let me know anything else ![]()
ok Alfredo, thanks a bunch when i get back on the logger ill recheck the tab sequencing again…have a great day…-Dave
Hi David! Thanks so much for your patience! I just did a test on tab order again and it’s working correctly on my device. Is that still broken for you?
HI JIm… Got up and went into the office to check the tab sequence and did a dry run with a call and its A-OK!!, CONGRATS on fixing he sequence. We can now chalk it off the To-Do list… Now to work on the "auto-populate “Their QTH” field… The logger i s doing a FB job, Thanks again for the team’s hard work…
Now i’ll go back under phones on 30 or 40m until 11 11 AM…7
3’s from cold central PA!!!
-Dave k3dgr (CFO#1014,CWOPS#694)
Thank you David - one day at a time!! Thanks so much for being a founding member. We’ll keep working through that and I’ll be sure to keep you posted!
