Log QOL requests
Hey team! Love logging and using the app, and really enjoy all the functionality going into it! So first off, thank you! Had a couple of thoughts on things that would be nice (or at least convenient) to have in terms of logging.
As a lot of hams travel, having the state operated from and to for each log entry would be great! I know there’s a way to change the grid square at the log level, but if it could be done also at least at a “state” or “country” level for each entry within a log it would be helpful to look back on!
Next, the map feature is great! But again, as there’s sometimes travel, having a different colored pin icon for the user vs contacts would be useful to visually see, instead of just two red pins on both ends.
Keep up the great work!
@K4WLX Hey Joshua!!
You can actually set multiple “saved locations”. Just go to ‘Log Contacts’ then click the ‘Gear’ icon. Then from there under ‘Saved Locations’ click, ‘View/Add Locations’, then when you create a new logbook set that newly created location. This can also be done on existing logbooks as well via the ‘Gear’ icon. Just go into whatever logbook and update the location.
For the map suggestions, we actually have SEVERAL new custom features that are in development that will allow users to customize their map view in several various ways including pin styles/colors, map styles, etc, etc :wink: I don’t have a timeline on this at the moment but I do know we’re working on it and we’re close!
I hope this helps!
