Make band change to match frequency automatically [IMPLEMENTED]
When using the android app, if you change to another frequency, the app drops the band and you have to reselect the band button. It would be nice for the band to automatically change to match the frequency. One less thing to click. I don’t know if any of the other apps work this same way.
Are you using the app from the Google Play store, or the web app in a mobile browser?
The Google play store app.
Is this while logging or editing contacts?
Logging. For instance: if I just made a contract on 14.225 20m ssb, but then I spin the dial and I make a contract on 14.236, it errors out the band and mode. Could it be smart enough to know if I’m on 14.xxx, then that’s the 20m band?
@W8NGS Hmm. It should be doing that already. Could you send me a screenshot right before and right after the error occurs?
I found it does it as long a you enter the decimal point.
Great! Thanks for responding! Yes, our system does require a decimal point in the frequency in all cases.
