How do I make a daily contact map? I can make a total contact map, but I really want to be able to make with the contacts I made on that day.
Thank you, Scott / NF5R
@NF5R Scott
We’ve just pushed a new feature called the ‘QSO Map’. Goto the main “Logbooks” page then click the ‘QSO Map’ at the top. Then you can select a date range or just click the ‘Today’ button from the date filter (top right of the page, probably says “All Time” by default"). This will pull your QSO’s from today and then you can customize the map, add labels, etc and share this if you’d like.
Thank you!
I tried it today as you instructed and there’s still an issue. I downloaded the map set by today’s date. It was still a map of my total log and not today’s contacts.
@NF5R the date selector can be a lil finicky we are working on some updates.
Here is how to do it.
I will try again tomorrow. Thanks for the update.
