When I look at the QSO map it would be nice in the customize area to be able to filter down to what you want to see on the map by mode or band.
Show off my ssb ? Show off my ft8 ?
Not just everything at once.
@VE3YHW So you can do this via the new QSO Map (âLogbooks â QSO Mapâ) Then click the âFilterâ button in the top left and then select the mode, band, logbook, country, etc etc
Additionally you can use the âCustomize Map â Advancedâ settings and then set a different pin type for say FT8 contacts too, but I think the filter option is what you are looking for.
Iâm mostly a mobile user. The app doesnât have this option ?
@VE3YHW I see, yeah the mobile app initially was meant for portable ops however we are starting to make it more feature rich. Starting with the latest map updates weâve added over the past couple of weeks. We are switching over to this new map styles/changes on the web app as well. With that said, we will be adding some of the features from the web app into the mobile app, where the maps are concerned.
