In Safari (MacOS), in the Share Map interface, there’s a Download Image button (under the share options at the top of the screen). When that button is clicked, the resulting jpg downloads but when opened, the jpg does not have the actual map portion of the screen. It only has the stats on the left hand side. I tried the same functionality using Chrome (MacOS) and it worked as it should.
@KZ8Z Are you still facing this issue?
Yes, issue is ongoing. IE. The map share link display a blank (just white space) map when opened and also the downloaded jpg is missing the map in the same manner.
Just wanted to give you an update. We have a fix that is in process and should be released very soon. Sorry for the trouble with this one!
Brad
K4AZE
Thanks Brad. I always appreciate the work you guys do AND the great communication you have around what’s being worked on (and what’s not). ..like this email you sent me.
Dave (KZ8Z)
@KZ8Z Absolutely! Most of us are radio enthusiast as well so we are trying to build a platform that we would want to use, not just a product to try and make money! There are so many features we are wanting to add and working on adding to make a solid product! Thanks for the kind words, it really doesn’t go un-noticed!
Thanks!
Brad
@KZ8Z Hey David!
Sorry for the delay in getting a fix pushed for this but this one turned out to be a tricky one for some reason. We made several changes but this should be good to go now. Thanks for all your support and letting us know about this!
Thanks Brad. I just tested it and it does seem to be working now. Nice Work! Thank you!
By the way, and maybe this should be a different bug but I noticed on the map view that it does not display all of the QSOs. It always displays a pin drops less than the actual number of QSOs. I also had a friend bring this up to me. We are both on Macs. Attached is an example. there should be 38 pin drops but there are only 25.
Should I create a new ticket for this?
@KZ8Z Hey David,
Interesting! Yes please create a new bug report for this and we’ll look into it. That way its easier for us to keep track of them.
This blank map issue seems to be back in Safari. It appears that whatever recent map changes were made, those changes backed out the fix that was in place. The downloaded map is now blank again. CCing @N0APX @K4AZE for visibility.
@KZ8Z Hey David, Thats odd I tested it on Safari and didn’t have any issues (a couple of our devs use mac’s as well). I’ll reach back out to the team and have them take a look and we’ll push another fix for this! Sorry for the trouble!
K4AZE
@K4AZE Just tested this on Safari and I’m getting the same issue. @KZ8Z We’ll definitely get this sorted out for you! Thanks, and 73!
Andy N0APX
WRL Product Manager
Andy, same issue here. It’s been at least two days since it started. MacOS and Safari. Brave browser works fine.
Thanks!
Tim
@KI5OOS Hey Tim,
Yeah i got your bug report. We already have a ticket for this and are working on a fix. It should be pushed live in a day or so at the most.
