Thanks Brad and good morning to you too.
I see a couple of reasons why probably things arent working for me, and it has to be to my current set up. I am unable to replicate your guidelines, but because my actual set up, which I will try to summarize:
- I run a remote station comprised of Flex 6400, a Mac Mini (main shack computer) and a Windows PC (backup shack computer) -both computers run at the same time.
- On the Mac I run SmartSDR for MacOS, MacloggerDX, Gridtracker and JTDX (on some days I run the normal Wsjtx). In the Mac, Jtdx send udp to a broadcast udp so all apps gets the info and they talk among each others easily. And I have GT sends udp to a second GT (running on the Windows PC) on the same network. Qso´s are logged to MacloggerDX fine.
- On the Windows PC side of things, GT picks the udp and send it to Log4OM and N3FPJ (my secondary and third loggers, I will cease to use N3FPJ once WRL is running full time). Those loggers are fed with direct connection using GT´s list of loggers.
As for your excellent guidelines and instructions (kudos for a very detailed job), there are a couple of things I wont be able to set without disrupting my “now working configuration”:
- On the WRL cat control I must connect the radio as Flex 6xxx
- On JTDX I cannot change radio to Hamlib (it needs to stay as a Flex)
- On JTDX I cannot change to primary UDP info as it is sending packets to a broadcast ip/port so every software can read.
- On GT I cannot change the “send udp to second GT”, because it is sending everything to the Windows PC.
Therefore, the only available settings I can use to integrate WRL with JTDX are:
- As Flex Radio on WRL cat control app
- To listen as Wsjtx:
- Using Secondary UDP on JTDX, directed to the port set on WRL Cat control
- Using HRD Logbook connection directed to the port set on WRL Cat control
- To listen as N1MM
- Using N1MM connection directed to the port set on WRL Cat control
When I use GT, it sends and ackowledges the Qso´s as “logged to” in both HRD and N1MM, so GT is sending the info to that port, but WRL is not picking up, as logbook nevers updates with new Qso.
Is safe to say that integrations with QRZ (for both look up and download/upload) is working great, as the Lotw integration too. No worries on those two things.
If, in order to have the integration working, I must change either the primary udp on JTDX/Wsjtx or the primary and secondary udp on GT, then I wont be able to do it, due to my complex set up (we ham never work with simple things, we love to complicate ourselves!).
I also tried everything without the cat control function connected but only using the listening feature, with the same results. Also I tried it in both computers (Mac and PC).
I hope this explanation makes sense. Meanwhile I´ll keep trying to make things work.
Thanks a lot and enjoy your Sunday.
73, Santiago HI8O
