New Map comment and issue
Was just watching the “Customize Your WRL Map & Share It Anywhere - User Guide”
Love all the new stuff. But I have s problem.
Here is what I am seeing when I open the map. This looks correct.
When I try to customize. I see this. You stold my QSOs Hi hi
So, not sure if that is an issue. I do not want to save any changes, if it messes with my original map and deletes a bunch of QSOs. I was going for the GLOBAL version.
Thanks
Bill
W4WCS
Hi William @W4WCS
This is only a design preview map. When I go to the customize map menu myself, I see the exact same map as you see: Also my position is shown at the us east coast, with some contacts in US, some contacts in Europe, 2 contacts in South America and 1 contact in Africa. So this is only a sample map to show you the design. There is no connection to your real contacts in your logbooks.
So don’t worry and click on ‘save’. Everything is all right.
73 Pepe
@W4WCS Hey Bill, This is just the preview window. it doesn’t show all your qso’s in the preview window. Once you save your map customization and then goto the map tab in your logbook it will show all your qso’s.
I hope this helps.
Same exact problem here. I did the HI QSO Party and when I customized it, I had the EXACT same map, with me on the east coast. Thanks for the tip! K6WDE
Takes Pepe,
Appreciate it.
Bill
Gotcha!
Thanks.
Bill
Brad,
I looked at my map this morning after customizing it into GLOBE mode.
Unfortunately it is incorrectly drawn.
Map mode is fine.
Bill
W4WCS
@W4WCS Hey Bill,
I just confirmed this is happening on my end as well. I’ll reach out to the team and have them take a look for you.
Thank you Sir.
@W4WCS Sorry for the delay with this. We’ve pushed some fixes for this and all is working as expected now.
