Powering a 240 volt amp
Can i use a transformer 3000w to take 120v to 240v to run a 1500w amp 240v plug
My first question is Why ?
You do not have two 110 outlets that are powered by different phases (sides of your Circuit Breaker Panel) ?
If yes, to the above then creating a 240 or 220 Volt outlet is much less complicated than you are thinking.
If I have lost you in my simple reply then my most sound advice is hire an Electrician
Always follow the NEC (National Electric Code)
Doing anything less can be extremely costly.
Steve KG5VK
A 240 transformer is about 250$ electron plus beaker plus wire plus plug plus wifes scorn a lot more
My wife said they used them over seas when needed would it adversely affect the amp
