I might be confused about how the spotting page works, but, it’s kind of a pain to use it for spotting POTA since it doesn’t open a new page when you click to log the contact. So, you have to come back and forth between the logging page and the spotting page. Can this be fixed and could you add the option to select a default log on the spotting page so we don’t have to choose each time we log someone from the spotting page?
@N3VD For actually logging you should be using the spotting tab inside the logbook, which has the same spots as the spotting page.
Ah, well… duh… I feel like an idiot!
Doing that works beautifully. When I spot someone else, it doesn’t spot on the POTA page under the activator’s spot. Will we be given that ability at some point or am I, again, missing something obvious! Thanks for the great work you’re all doing.
@N3VD That would be a good feature for sure, that it could respot on POTA page. Good thought
