Hi The current cluster choices are mostly USA based Clusters meaning there will be spots that are not being heard in the UK in which case they wouldn’t appear on a UK based cluster, please could you implement a user difinable field so that i can add my preferred cluster into WRL, for example dxspider.co.uk on port 7300 with your call sign as a login, I am sure there will be a long exhaustive list of clusters so a user defined field so that we can save our preferred cluster(s) would be great.
@M0WND Hey Tony,
Yes this is on the list, albeit a long list at this point but its coming.
Yes please, I’m asking for the same thing for the Spanish cluster DX Cluster | URE — that’s the only thing missing for it to be absolutely perfect. Everything else is great, everything works perfectly: CAT control, WSJT-X connection, imports, exports, all of it is absolutely wonderful. The only thing left is being able to connect our favourite cluster. A million thanks."
Hey hope you are well… just wondered how close we are to getting a user defined cluster setting, or please could you add dxspider.co.uk on port 7300 and a field /pop up to enter our call sign for the login.
@M0WND spotting updates are in the works ![]()
Has there been any update on this, I see all these amazing new features released but yet the platform is still very US focused in terms of spotting, whilst I am not a programmer but surely it isn’t that complicated to add in a field where you can select a preferred cluster? Will this feature be available before this coming Christmas ?
