Where do I look to find out about the errors in my log upload?
Thanks!
Hi Ron, was that an import to a new log, or was it a merge?
1st upload to existing log with no contacts
73 es God Bless de KK1L, Ron <>< kk1l.com
@KK1L we don’t have a way to display the error logs on the front end yet, but we can take a look at this on the backend and get back to you.
Thanks for all the patience, I know you have had a few bugs recently so thanks for baring with us!
All good! My guess is there is a similar reason for those to have been failed. The file was generated from DXKeeper for all contacts from my home QTH. It is suspicious that it is an even 54000 Q’s which had errors…Maybe another limit now that you opened up the file size limit.
@KK1L We’ve released a hotfix for this issue! All of your contacts were successfully imported, it was simply an issue with the type of calculation we were running to display the counts. Thank you SO much for reporting this issue! We appreciate you being such a great active member of our community!
73,
Andy N0APX
WRL Product Manager
No problem Andy. I fully understand there are bugs to work out, especially with edge cases. Thanks for keeping right on things!!
