I have WSJT-X, GT, and N3JFP syncing together when I complete a contact no problem. But, for some reason, I can not get the same contact synced into WRL. All have the same port#, I have the WRL CAT radio control off but the log sync listening, and the WRL app open. Not sure what I am doing wrong.
@W9AWX Hey Gregg,
Below is a guide on how to set this up properly. Since you are not using the integrations app (formerly called the WRL cat control app) for rig control (cat control) then you can skip the ‘Radio’ tab settings in step #5 (#5.1) of the documentation, but follow the rest of the steps in #5.
I hope this helps! Let me know if you are still having trouble.
Figured out the integration issue. Had to change the code to make it work based on te latest integration guide.
@W9AWX Perfect! Glad you got it working!
Thank you @K4AZE as always!! ![]()
