Add VaraC to the list of modes? [IN PROGRESS]
I have been using Varac and logging them under DIG, a VaraC option would be nice
K4GDJ
@K4GDJ Ok, I’ll reach out to the team and see if anyone has any objection to adding it (don’t see why we wouldn’t add it), we need to add a Echolink as a mode as well. I’ll update here after we’ve had a discussion and added it.
Thanks @K4AZE !
From the official ADIF Standard, VARAC is a submode of DYNAMIC: Released ADIF Version 3.1.5, updated 2024/11/28 (search for Mode Enumeration)
Perhaps we should add VARA in the drop-down, and then need to map it to DYNAMIC for ADIF exports.
We purposefully don’t want to list ALL the sub-modes from the ADIF standards, because it would be overwhelming.
@N0WRL That makes perfect sense. Yeah i think adding VARA or VARAHF and mapping them to ‘DYNAMIC’ makes the most sense. That way the user can set it as VARA/VARAHF and then if/when they export its set to the ADIF standard as it should be. Good call James!
Have you been able to get VarAC to send logged contacts directly like we can with WSTJ-X? I tried to use the same settings that work with WSTJ-X and it didn’t work.
@KQ4Y Hey Rick,
We have not had a chance to integrate the cat control app with VARA/VarAC yet unfortunately.
That’s OK. I was curious if the OP had managed to find a way to make it work. For now, I just send it to N3FJP from within VarAC. I just started using it and haven’t even made a QSO yet!
