Adding Radios for Satellite Operations
I have a logbook for HF operations using my IC-7610. I created a Satellite Ops logbook that I want to “link” to my IC-9700. How do I add another radio and link it to a logbook?
73s,
I’m also not a Free Member anymore, but for some reason this BBS states that I am.
BBS… wow, haven’t seen that term used in a while. :sweat_smile:
Signed,
The former sysop of Apex BBS in The Woodlands, TX, a Mustang Software system running Wildcat!. 713-362-9096 I closed it down in 1996.
@KA5UTN I’ve fixed the display beside your callsign in the community chat. Currently you can only assign one radio to your logbook.
Thanks for the member fix. As for one radio per logbook, I understand that.
I have an HF logbook connected to my IC-7610. I created a new logbook called Satellite Operations and I want to link my IC-9700 to that logbook, but the only radio available is my 7610 HF radio.
How do I add my IC-9700 VHF/UHF to the new logbook I created?
73s,
It was shorter to type that than WRL Community Chat .
73s,
You just need to go into your profile on the web app and click on the “my station” button and add a new radio. Then once it’s created just go into your logbook and go to logbook settings and then click the “equipment” button at the top and select the new radio you added. Now this doesn’t really serve any purpose other than for you to know that the contacts in this particular logbook were made using X radio and Antenna. You can use the filter opens in the qso manager to filter by equipment as well as the qso map to filter by antenna or radio too but this doesn’t have any bearing on a physical connection to the radio. That’s all done via cat control.
I’m sure down the line we can add the ability to assign more than one radio or antenna to a logbook though (to answer your first question).
Once everything is setup on the web app it will all sync to the desktop app.
I hope this makes sense and at least somewhat helps
Thank you Brad,
It worked perfectly. You also addressed the underlying reason why I wanted to add my IC-9700 for Satellite Ops. I wanted the radio link to update the logbook I’m using for satellite ops. Just like my HF radio does for that logbook. That’s another issue because the 9700 CI-V jack has to be connected to my S.A.T. from CSN Technologies to control the radio and rotors. Since the logbook only reads the information and doesn’t control the radio is there any other way the logbook could get that information – perhaps the LAN cable or USB connected to the computer?
73s,
Mark, KA5UTN
@KA5UTN Hey Mark, i’m honestly not sure but I dont think that if the CI-V cable is being used that you can run rig control via another usb cable. (see below from a google search). The only other thing I could think is to run VPSE (virtual port serial emulator) to be able to access the com port for two applications, however this could cause some issues.
Google Search Result:
No, you cannot simultaneously use the USB port for rig control while a CI-V cable is connected to another application or interface.
The IC-9700 shares a single internal CI-V bus for all control interfaces. According to user reports and technical guides, connecting a PC via USB while another device (such as a CI-V interface or PTT extender) is attached to the CI-V bus causes conflicts that prevent both from working correctly.
To operate the radio via USB, you must ensure:
  • The CI-V USB port setting is configured to “Unlink from [REMOTE]” in the radio’s menu.
  • No other hardware is physically connected to the radio’s CI-V or DATA jacks, as the USB connection takes precedence and the internal bus cannot split traffic to multiple controllers simultaneously.
