hi, i have 2 call logs, one is m0kpd and my adif file uploaded all ok. Now i have tried to upload my adif file for m0kpd/m and it has only loaded 4000 contacts instead of 70000.I tried again after and it is just the same. Is there a limitation?
It looks like you still have an import running however it looks like currently there is 6603 duplicates so far out of the 37267 total that is importing.
I too have multiple logbooks for 2 different calls on QRZ and it would be great to be able to synch each logbook on QRZ to the 2 different logbooks I have on WRL
Yes if a QSO has the same freq, band, mode and within a small time window it will be considered a dupe even if its in a separate logbook. Its done that way to prevent duplicates in analytics. I hope this helps.
You can use the ‘Analytics’ page via the main navigation (on the left hand side of the screen of the web app) to view analytics across all logbooks. Additionally you can go into logbooks and goto the ‘Stats’ tab on the right hand side where your “log” shows to view stats per individual logbooks. We have ALOT of new analytics features and dashboards coming once we finish our database upgrade that we are in the process of testing before releasing.
Let me know if you have any other questions or need a hand with anything! Happy to help.
