As a guy with an old brain I am easily befuddled when booting rig cat control and it asks if I want to sign in. Sometimes I hame already signed in and I find that I have two browsers open with WRL. Am I supposed to bot rig control first ?
Andy K3UK
Andy K3UK
@K3UK Andrew,
Yes, I found that opening everything in this order is what works best for me (your results may vary).
Thats what works for me at least.
Thanks, I am doing CW only at the moment. I did try WSJTX yesterday and had no luck . Now I know your sequence I will try that too.
Andy K3UK
I am missing a step, I think . Normally when integrating WSJTX with other logging application I boot WSJTX first and allow WSJTX to have the primary CAT control . Then I boot the logging software and the data from WSJTX flows to the logging software . Do I do that ? I am a bit puzzled about how, if I do that, clicking on spots in WRL will be executed because I assume WSJTX is controlling the CAT port.
Andy K3UK
Got it now, My UDP port was different, fixed that now. Very nice integration. 73
@K3UK ok great!
