Cat control logbook sync
Cat Control fails to sync, giving error of Edge Function returned a non-2xx status code
@KN4V Hey Kalib,
Are you using the latest cat control version (v1.1.2)? With this version we’ve added a ‘Contact Log’ that shows the sync status of each contact. Also, what are you trying to sync? WSJTX/JTDX, N1MM, N3FJP contacts?
I have a lot going on, lol. I am using the newest cat control windows app. Wsjt-x from a networked Linux machine that is housed in another part of my house (next to my rig). Was working perfectly, but I recieved my vanity call (KN4V was KF4VXP) and now that I have changed call it isn’t syncing from local to cloud. Not sure if I need to create a new logbook now that I have the new call and that could be issue or what. Any troubleshooting steps I should take?
@KN4V You’ll probably just need to log out of the cat control app then re-login in, then go into the settings of the cat control app and refresh the logbook list, then re-select the logbook and THEN start the UDP listener.
I logged out of everything, logged back in and created a new logbook just for WSTX and now everything appears to be working. Have a great day!
@KN4V ok great
