CQ WPX Contest log template
I am using CQ WPX Contest template to log. I would request that in addition to Field to record the other station’s serial number that my serial number be in the template. Additionally, input template should be rearrange so the other station serial number Field is visible without shrinking the keyboard. Both makes it difficult to input log info quickly.
Thanks, Stacy WA4IDS
It took me a minute to realize you are talking about the mobile app. Yeah that should be changed as you said.
On the web browser it is like you are requesting & is working well for me.
@WA4IDS The mobile app is not really meant for contest logging its meant for portable logging for activities such as pota, sota, wwff, etc. Now with that said, we will be adding contest functionality to the mobile app eventually.
You should be using the web app for contesting currently.
You are right. I should have been more specific about the version i was using.
I understand about the usage of the mobile app. I should be using the web version but I am using my portable setup away from my shack. I worked out a work-around that made things smoother so it’s all good.
Thanks for the replies!
@WA4IDS of course! No worries at all. Using the web app in a mobile browser would effectively do the same as the web app on a laptop/desktop :wink:
