in the contest log CQ WW WPX there is a box for serial number is this for what we send or what the other station sends us, or we suppose to log both in the same box?
@N0ZHE
This will be changed in just a few. We are finishing up a few changes ahead of the contest tomorrow. There will be two fields, one "Serial # Rcvd’ which you’ll put whatever serial number you get from the other person and the other field is “Serial # Sent” and this will be an auto incremented field starting at 001 (for your first contact, then 002 for the second and so on) that you will give to the other party. Does that make sense?
We are also going to be pushing a Cabrillo export (you will still have the ability to export an ADIF as well) for this specific contest. We will continue to improve the Cabrillo export going forward but wanted to at least have this functionality available for tomorrow.
Brad
K4AZE
thanks
@N0ZHE Changes are live! Good luck in the contest!
Brad
K4AZE
I don’t see the fix still just one box…
Goto “home” hold shift on your keyboard and press the refresh button in your browser
yes, I cleared the browser history and then it loaded up fine.
Perfect! There is still quite a bit of work we are going to be doing for the contesting side of things in the very near future. We have some minor quirks to fix and LOTS of updates we want to push out. I see your THIRD PLACE so far !!! I LIKE IT! Good luck!!!
Brad
K4AZE
