Hello!
I’d like to have dedicated fields for the sequential numbers sent and received during contests.
The sequential number sent could also be automatic (incremental).
In the last contest, I found it difficult to keep track of the sequential numbers I received.
I’m sure this would be appreciated!
Thanks
IU1WVN – Nicolas
This already exists inside the contests. For each contest you participate in on WRL you need to enroll in that contest which creates your contest logbook which the correct contest exchange fields. For contests with serial numbers there is a sequential number that is shown. (see below). It shows the Serial # for the person you are taking a serial number from and then the serial number you are currently on.
after the contests are complete you can export your logbook as a cabrillo log as well but again all of this needs be done through the contests & events page by enrolling in the contests.
